Taking a backup
sbunyan
Taking a backup
Post by sbunyan »
Hi all,
I am trying to implement a system whereby a backup of an existing directory is taken before doing an upgrade. For this we had to code our own dll which will copy a directory and it's contents.
The declaration for this is as follows:
extern DLL_MODE int CopyDirectory(char *SourceDir,char *DestinationDir,int &Status);
When I call this dll in the InstallAware project, the CopyDirectory copies everything as it should however execution is never handed back to the installer. If I run the installer in debug mode, everything crashes after the Call Dll function, however the directory is copied.
My call to this dll is as follows:
~InstallAware Clipboard Data~
~Call DLL Function~
~{E9D6FDF5-6201-4939-B93A-1C75E8D32D37}~
~$SUPPORTDIR$\\DmmDongle.dll,_CopyDirectory,long,Result,"pointer to string",$Source$,"pointer to string",$Destination$,"pointer to long",$Result$,$~
~mIDEFunc.dll\\mEXEFunc.dll~
Can anyone shed any light on this?
Thanks in advance,
Sinead
sbunyan
Post by sbunyan »
Just discovered that if I rearrange the sequence of the parameters to the dll function all works ok.
The function works as follows:
extern DLL_MODE void DmmCopyDirectory(char *SourceDir,int &Status,char *DestinationDir);
however if I declare the function as
extern DLL_MODE void DmmCopyDirectory(char *SourceDir,char *DestinationDir,int &Status);
this will not work!!
I don't know why this is the case, maybe someone out there has some ideas?
Sinead
