MessageBox text
sdeschenes
MessageBox text
Post by sdeschenes »
I have an SFX installer that has been localized. When I run the SFX, a message box appears telling me that InstallAware is verifying the contents of the package. However, some of the words don't fit in the message box. See attached image.[img]
Is there anything that can be done to fix it?[/img]
Alex_Ronquillo
Post by Alex_Ronquillo »
Edit the size of the dialog with IA Dialog Designer. You can also edit the size of the label area.
Alejandro Ronquillo
sdeschenes
It looks like that the dialog only appears when you run an SFX. The dialog doesn't seem to be associated with one particular theme. Is there anything else that can be done?
