Installer hangs at startmenu
abz
Postby abz » Fri Nov 16, 2007 3:55 pm
Am wondering if you could help.
I have created an installer in which I have unchecked registration, setuptype and componentstree. Destination works ok but when it gets to startmenu the "Next" button is disabled and the UI does not respond to clicks. I have to kill the process in task manager.
I have also tried including the unchecked dialogs but it makes no difference.
Would appreciate any guidance.
Many thanks
Abz
Postby CandiceJones » Fri Nov 16, 2007 4:12 pm
Look at your dialog script and make sure its not disabling the Next button for some reason.
abz
Postby abz » Fri Nov 16, 2007 4:26 pm
Thanks for the reply.
I have pretty much worked with the design mode and not touched the msi code. I've had a look through and there is no disabling code.
Somehow I think there are other elements at work because the UI does not respond at all, I can not move the window for example.
Would appreciate any further guidance
Abz
abz
Postby abz » Fri Nov 16, 2007 4:53 pm
I have just recreated it and it works fine.
I must have messed with some setting somewhere.
Manay thanks
Abz
Return to “Non-Technical”
Users browsing this forum: No registered users and 110 guests
