Remove the silent install of SQL Express 2005 SP2
Roostar2004
Post by Roostar2004 »
I was wondering if there was a way to remove the silent install of SQL Express 2005 SP2 from installaware. I would really like to check that it is being installed correctly by installaware. I know that in installshield you just have to put a /qn to remove this option but that does not seem to be the case in installaware. Can anybody help me?
Roostar2004
In case anyone is wondering there is no way to do this that I hace found.
jimo
Post by jimo »
Yes there is a way to do this in InstallAWARE!
1. Your original statement was
Well, check it after the install is complete and verify that all settings and options are correct and the use it.
2. Create your own file bag for the SQL Express set up files and just run it, all the dialogs will come up.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
