Having trouble with Web Deploy - 7zip files not found
MobileMark II
Postby MobileMark II » Mon Nov 07, 2005 8:22 pm
I'm in the proess of evaluating IA...
I have created Web-Based EXE project. My project results in 3 files being built: My setup.exe file and 2 .7zip files. All of this is as expected. After building my project, I'm posting the two .7zip files to my web server (IIS). When I go to install, it appears that my setup.exe cannot access the .7zip files.
My problem appears to be with my IIS web server not wanting to serve up .7zip files. Can someone explain to me how to make this all work? I've tried adding .7zip files as an additional MIME Type, but either that doesn't work or (more likely) I'm doing it wrong.
Thanks in advance.
MobileMark II
Problem Solved
Postby MobileMark II » Mon Nov 07, 2005 8:53 pm
I'm not sure if it was simply a matter of IIS catching up with my request to serve up .7zip files or not, but it started working. I assume adding an additional MIME Type to IIS is the key.
sinan
Postby sinan » Mon Nov 07, 2005 8:54 pm
Adding 7zip as a mime should work. If it doesn't its probably some global setting overriding it. You can save yourself the hassle as follows: just rename the 7zip extension to anything that is servable (like zip), and then update the web media block download URL, and rebuild your setup.
ManishDev
Re: Problem Solved
Postby ManishDev » Mon Apr 16, 2012 10:30 am
MobileMark II wrote:I'm not sure if it was simply a matter of IIS catching up with my request to serve up .7zip files or not, but it started working. I assume adding an additional MIME Type to IIS is the key.
How were you able to resolve this? What MIME types did you add?
Re: Having trouble with Web Deploy - 7zip files not found
Postby FrancescoT » Wed Apr 18, 2012 3:11 am
Dear user,
I have solved just renaming the file with ZIP extension ... and works fine.
Have you done it?
regards
Return to “Non-Technical”
Users browsing this forum: No registered users and 13 guests
