Is it possible to perform the “Run Program” over an http-add
FinlandRobert
Post by FinlandRobert »
Is it possible to perform the “Run Program” over an http-address?
Example: I want to run a separate program located on http://someaddress.com/applicationfolde ... cation.exe
Thank you in advance!
Alex_Ronquillo
Post by Alex_Ronquillo »
It is possible to do that with some limitations:
1.- The run program command opens an explorer window
2.- The explorer "Run/Save" dialog appears
3.- IA doesn't wait for the program to finish execution.
However, the program runs, which at the end is what you want.
Alejandro Ronquillo
