Installshield vs. Installaware
uhillig
Postby uhillig » Wed Nov 28, 2007 7:28 am
i plan to move from Installshield to Installaware. Is there a way to build updates with Installaware, in a way tha previous Setups from Installshield gets automatically removed?
Best Regards,
Ulf Hillig
Postby CandiceJones » Wed Nov 28, 2007 5:12 pm
Hi Ulf,
Yes this is possible.
You'd use the Run Program or (Un)Install MSI Setup commands to remove your previous InstallShield version, once you detect it in the systme using Read Registry or Is MSI Setup Installed.
Return to “Non-Technical”
Users browsing this forum: No registered users and 75 guests
