Get System Information problem
jerin
Post by jerin »
I used the function 'Get System Information' to get the computer name and
store it in a variable. When I use this variable for running 'MS SQL Server Script', it is not working. Computer name is fetched in the variable I use (I can check it in Add watch). When I explicitly store the computer name in a variable and use it, it works. Also if I hard code the computer name in 'MS SQL Server', it works. Do I need to do any work around for making the variable to work?
Please find the code used below:
~InstallAware Clipboard Data~
~Set Variable~
~{74655FF6-47C4-4CB0-9C30-A3E440CF8F61}~
~computer1$MYAH$MYAH$FALSE~
~Set Variable~
~{063A3842-45F1-4819-AD36-E193C24019B5}~
~domain1$MYAH$MYAH$FALSE~
~Get System Settings~
~{DD44C612-A124-44B4-9077-300FAAFF6833}~
~computer1~
~61~
~{2DC05A20-6281-436D-A0EB-3262B5F2F76E}~
~domain1~
~62~
~MS SQL Server~
~{8B049ADD-2742-4896-8310-003B20B94D86}~
~$computer1$,$SqlInstance$,WFUserDetails,sa,sa,Res,"INSERT INTO [UserTable] (UserName, Password, FirstName, LastName)$NEWLINE$VALUES ('Right', 'Pass', 'Jerin', 'Jerin')",0,0~
~mMSSQLIDE.dll\\mMSSQLExec.dll~
Jerin
