Installing shorcut into Users Startup Folder - How to?
MobileMark II
Post by MobileMark II »
Is there a pre-defined variable for the "user's startup folder?" I want to install a shortcut into the user's Startup Folder so that my program launches whenever the user starts Windows? What's the best way to do this?
K-ballo
Post by K-ballo »
You can retrieve that folder via "Get Folder Location", look for the option Start Menu->Startup Group.
Gizm0
Post by Gizm0 »
Actually the best way to do this, is to put a Registry key on the "Run" key section of HKLM\\SOFTWARE\\Windows\\CurrentVersion\\ or HKLU\\SOFTWARE\\Windows\\CurrentVersion\\, depending if you want to start the program only to the user who installed it, or for all of them..Use "Write Registry" function.
