Require .NET 3.5 Framework using Microsoft bootstrapper tool
gmcbath
Postby gmcbath » Fri Dec 07, 2007 5:16 pm
I'm a newbie and purchased the product specifically for using it with the .NET 3.5 Framework (long time InstallShield user - look forward to escaping the tar pit) so please forgive me if my question is super simple for you long time InstallAware users.
My project requires the .NET 3.5 Framework and although I can include the framework with my project, or use Web Media Blocks to host the framework on my own servers, what I really want is this:
1) Tell InstallAware my project requires .NET 3.5 Framework.
2) Have InstallAware launch Microsoft's .NET 3.5 Framework bootstrapper utility named dotNetFx35setup.exe to perform the actual framework installation.
3) On the Application Runtimes view if I check the .NET 3.5 Framework, doesn't it require me to either include the framework in the setup, or host the framework via Web Media Blocks?
What I want is the 3rd option (does it exists??) - InstallAware checks the requirements (need 3.5 Framework) on the current machine, but doesn't include the framework in the setup kit (don't want a large setup kit), or be required to host the framework myself.
The reason I don't want the framework included in the setup kit is simple, I'm ok with a huge setup kit the first time a user performs an installation, but I don't want them to have to download a large setup kit each time thereafter once they have the framework installed.
Is what I am asking possible?
Can anyone point me in the right direction?
Thank you for any help on my issue!
Alex_Ronquillo
Postby Alex_Ronquillo » Mon Dec 10, 2007 5:25 pm
That is easily specified by checking the runtime application for .NET 3.5.
That is also included if you check the runtime application.
Take a look at script setupnet35. You can modify it to create a webmedia block instead of file bagged the files in #IADIR#\\runtimes\\net35bin\\ directory.
Alejandro Ronquillo
gmcbath
Postby gmcbath » Mon Dec 10, 2007 6:05 pm
Thanks for the response Alex.
Are you saying I can modify the setupnet35 script to launch the dotNetFx35set.exe program?
I don't want to host any files myself, or include the framework in the setup kit.
The dotNetFx35set.exe is a very tiny program that will let the user install the .NET 3.5 Framework from Microsoft's website which is what I want.
Thanks - George
Alex_Ronquillo
Postby Alex_Ronquillo » Mon Dec 10, 2007 6:46 pm
That is right. Go ahead and modify the script to fulfill your needs.
Alejandro Ronquillo
gmcbath
Thank you
Postby gmcbath » Mon Dec 10, 2007 8:37 pm
Thank you Alex for the quick reply!
George
Users browsing this forum: No registered users and 21 guests
