How to extract COM information from .EXE?
asp
Post by asp »
Hi! I need to register my COM-server during installation process. In InstallShield I could set Extract COM Information as Registration Type in file's properties dialog. How can I achieve it with InstallAware? The only method that I expect will work is to manually set all necessary registry values in Registry pane. But it is so annoying...
SteveDude
Post by SteveDude »
In Design Mode, select Registry and then Import. Select your COM object and the information will be imported into the script. You will then need to edit the hard coded paths to variables in MSI mode using search and replace.
