I have a similar problem to other posts where I need to assign the product version using miabuild.exe and adding a compiler variable to the command-line. However, I'm using InstallAware Developer 7 and when I go to the Project Options window to attempt to create the compiler variable, I get the message that "Compiler variables are only available for InstallAware Studio and above"
Am I missing something....or is there another way to perform this operation using the Developer version?
Product Version
Alex_Ronquillo
That is right, As you can see at http://www.installaware.com/right-edition.htm under Design Features --> Compiler Directives; this is only available in Studio and Studio Admin Editions
Alejandro Ronquillo
