self contained .exe triples install size
sparkyflint
Post by sparkyflint »
I am testing a self contained .exe that is +/- 570mb when compressed and complete.
the install from this creates a 3gig install (should be 620mb w/out compression). on investigation it has tripled the locations of the content from the program (it's multimedia heavy).
Thoughts?
Help?
thanks
Alex_Ronquillo
Post by Alex_Ronquillo »
The problem is that you are installing a folder in the form:
Install Files Folder1\\Folder2\\*.* to $TARGETDIR$, include subfolders
and also you are installing another subfolder in the following way:
Install Files Folder1\\Folder2\\Folder3\\*.* to $TARGETDIR$\\Folder3, include subfolders
That is causing files in subfolder Folder1\\Folder2\\Folder3 being included more than once.
Alejandro Ronquillo
