Am wondering if you could provide some pointers as to how I can assign an icon that will show up in the Add-Remove panel but will not override the setup executable or extractor icons.
Many thanks
Use an Add-Remove Icon without overriding the setup icon
Alex_Ronquillo
What you can do is select the icon you want for the installer when building the project. In order to change the icon for the ARP, make sure the icon file is in the target computer, (you can include it as part of the installation), and set the value of the following registry key to the icon file:
HKLM\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\$TITLE$\\DisplayIcon
Alejandro Ronquillo
