Error: \"Setup resource decompression failure\"
SystemSmith
Post by SystemSmith »
I created a project using InstallAware Express. I then followed the instructions to copy that project (and all of the subfolders) three more times.
Using my text editor I edited the mia and mpr files so that each one had a unique project name.
I revised the three other projects to include the proper executables and components.
The original setup works: the other fail with "Setup resource decompression failure".
I have attached a zip file that contains all 4 mia and mpr files. The project FcartMnt is the first on created, the other three were cloned from it.
Thanks for any help you can offer.
// Walt //
// Walt //
Tillinger Consulting Corp.
SystemSmith
Here is zip file.
All4Projects.zip
// Walt //
Alex_Ronquillo
Post by Alex_Ronquillo »
Try doing the following:
1.- Make sure these files are in all your project folders:
comdlg32.msm
msvbvm60.msm
sysinfo.msm
r_32.ico
2.- Uncheck and check again the Windows Installer 2.0 runtime in all your projects that are failing.
That should sove your problem.
Alejandro Ronquillo
sdeschenes
Post by sdeschenes »
I am receiving the same error when I try to run my self-extracting installer. And this is happening on Vista Home Premium. It doesn't happen on XP Pro SP2.
