Use LOCMODE with Developer edition
Christoph Schneegans
I would like to set the pre-defined compiler variable LOCMODE to VARSONLY. However, I'm using the Developer edition, which does not support compiler variables. Is there a way to benefit from the VARSONLY setting?
Alex_Ronquillo
Doesn't work for me. The LOCMODE variable is not defined at all, e.g.
displays "Not defined". My command line call looks as follows:
[compiler if Variable LOCMODE is Defined ]
MessageBox: , Defined
[compiler else]
MessageBox: , Not defined
[compiler end]Code: Select all
miabuild.exe "D:\\LocMode\\LocMode.mpr" LOCMODE=VARSONLY
