Installation privileges under Windows Vista Home Premium
On some (not all) Windows Vista Home Premium installations, I have the problem, that during the installation process the message occurs, that the user has no privileges (or rights) to install the file xy.exe. By this problem all files with the ending *.exe are concerned. The *.exe files are compiled with VB6. If I copy the *.exe files manually into the installation folder, everything works fine. So what I do wrong?
Alex_Ronquillo
The only thing I can think of is that Vista is preventing windows installer from installing exe files. Check that windows installer is running with the right privileges.
Alejandro Ronquillo
MarcusSchmitz
Is it also possible that i need Code Signing? It it is so, is there any help or dialog for InstallAware Developer? Do you know other companys, that give Signings like www.verisign.com ?Alex_Ronquillo wrote:The only thing I can think of is that Vista is preventing windows installer from installing exe files. Check that windows installer is running with the right privileges.
