Setting TARGETDIR to include a subdirectory b4 Product Name
kksoft
Post by kksoft »
I am new to InstallAware having switched from Wise 9 Pro.
I am having difficulty understanding how to set the TargetDIR from the program files \\ product name TO program files\\subdirectory\\Product Name.
I have the EXpress Version so I cannot access the script. Is there a way to reset or modify this variable witjhout direct access to the script?
I would think I could do this, yes? Need help. Thanks
Kenneth G. Kirkpatrick
Alex_Ronquillo
Post by Alex_Ronquillo »
In the Project Properties of design view, there is a field "Target Folder" In there you can set your TARGETDIR to whatever you want.
Alejandro Ronquillo
Giplo
Post by Giplo »
How can I set this field to %SistemDrive% ??
Roostar2004
Post by Roostar2004 »
To do somthing like that I think you would need to have access to the MSI script. You would need to create a variable that has the destination for the system drive in it. You could then just put that variable in the "Target Folder" field.
