Proxy Server Issues
sagaris
Proxy Server Issues
Post by sagaris »
I am using installaware along with web-media-blocks.
My machine is configured to use a proxy server, if I browse using IE to the .7zip file I recieve a prompt to provide proxy credentials.
I enter proxy credentials and can access the .7zip file.
However, when using the installer created by installaware the attempt to download the .7zip file fails.
I understand that installaware uses IE's proxy settings transparantly, however this is not working for me. I am stuggling in attempts to resolve this since it should 'just work'.
Any help would be appreciated..
cheers
sagaris
Post by sagaris »
Found the answer to this now.....
Cheers
dencolp
Post by dencolp »
Hi sagaris,
What was your solution to this problem? I am having the same problem.
Thank you in advance for your answer.
Cheers,
dencolp
jimmc
Post by jimmc »
Does anyone know the solution to this problem?
I'm having it too.
csware
Post by csware »
i would like to have an answer to the described problem, too.
can you short describe your solution here?
thx
csware
Alex_Ronquillo
Post by Alex_Ronquillo »
I am not sure about Sagaris' solution. However, there is a workaround described at http://www.installaware.com/forum/viewtopic.php?t=3658
Alejandro Ronquillo
