Notification Settings - schedule update
RichardThor
Post by RichardThor »
When the user is setting up the auto update (schedule)
The Notification Settings dialog has three choices.
  • Notify...
    Download...
    Automatically...
:arrow: Is there a way to change the default value from the first choice to the last? (Automatically download and install).
Thanks in advance for your help.[/list]
- Richard T.
Alex_Ronquillo
Post by Alex_Ronquillo »
Sure, If you have IA Studio or up you can modify the properties of the controls in the dialog. Set the Checked property of the radio button you want to be selected by default to TRUE and the other two to FALSE.
Alejandro Ronquillo
