.net 1.1 won't detect upgrade to 1.1 SP1
Bugger
Postby Bugger » Wed Nov 16, 2005 6:45 pm
I've built a project that requires 1.1 SP1, and my test machine has 1.1, but not SP1 installed. I've verified this by checking the registry entry defined by MS here:
http://support.microsoft.com/?kbid=318785&sd=msdn#XSLTH4176121122120121120120
I've also got the latest plug-in package, referenced in this thread:
http://www.installaware.com/forum/viewtopic.php?t=343
And I've made sure to change the check and the install commands for the .net framework to "v1.1 with Service Pack 1". My IW version is "sp1.passion_update2_rtm.050927".
Have I screwed something up, or is this a bug?
sinan
Postby sinan » Wed Nov 16, 2005 6:49 pm
What exactly is the problem you are currently experiencing?
Bugger
Postby Bugger » Wed Nov 16, 2005 6:51 pm
sorry, too much coffee.
It won't detect that an upgrade (of the .net framework) needs to occur, which it should since I don't have SP1 installed.
sinan
Postby sinan » Wed Nov 16, 2005 6:53 pm
So you are testing for 1.1 with SP1, and you only have 1.1 installed; but the product fails to notice that you do not have SP1 installed?
Do you have 2.0 also installed perhaps?
Bugger
Postby Bugger » Wed Nov 16, 2005 6:55 pm
Yes that's correct... on both counts. 2.0 is installed on this machine.
However, this is still a problem, as the app is built for 1.1... not 2.0. Thus it needs SP1 to install.
Bugger
Postby Bugger » Wed Nov 16, 2005 6:56 pm
also, excellent guess!
sinan
Postby sinan » Wed Nov 16, 2005 7:00 pm
I had a hunch :) I've escalated this, expect an update shortly.
sinan
Postby sinan » Wed Nov 16, 2005 7:03 pm
Apparently, this behavior is as designed. The plugin reports the minimum available version on the system. Therefore, if 2.0 is installed, checks for 1.0 through 1.1 sp1 will return true.
If you application is not compatible with 2.0, you can check two additional things using the script code:
    1) That the .NET 1.1 folder exists ($WINDIR$\\Microsoft.NET\\Framework\\v1.1.4322); use the Does File/Folder Exist command
    2) That the SP1 update has been applied, by reading the registry key mentioned in MSDN documentation; use the Read Registry command
Hope that helps!
Bugger
Postby Bugger » Wed Nov 16, 2005 7:16 pm
well, it's not ideal, but it'll work. Thanks.
Bugger
Postby Bugger » Wed Nov 16, 2005 7:37 pm
Ok, I've done as you mentioned, but still no-go.
It will now detect the prereq, and download the web media block, but it won't install 1.1 SP1.
I'm assuming because the "Check\\Install .NET Framework (install v1.1 with Service Pack 1...)" command thinks it doesn't need to install, when it actually does.
BTW, even if this is built as designed, I can't think of a situation where this behavior is useful as currently implemented.
sinan
Postby sinan » Wed Nov 16, 2005 8:01 pm
I see your point :) Lets see what the product team comes back with on this one :D
sinan
Postby sinan » Wed Nov 16, 2005 9:16 pm
I have great news - I was able to communicate the value of your suggested approach, especially considering that .NET versions are best treated differently than regular file/runtime versions etc., in that having the latest version does not automatically provide backwards compatibility.
The word from the product team is to expect an update soon with a revised detection algorithm that checks explicitly for the indicated version :lol:
sinan
Postby sinan » Wed Nov 16, 2005 10:34 pm
Great news - plugins are now updated. Please re-download, and reinstall. Enjoy!
Bugger
Postby Bugger » Wed Nov 16, 2005 11:41 pm
Just installed the plug-in update from here:
http://www.installaware.com/blockspon/InstallAware%20Plug-In%20Update.exe
However, I don't see any difference, both check and install get skipped. Is there something else I need to configure?
sinan
Postby sinan » Thu Nov 17, 2005 6:18 am
I'd say, uninstall the plug-in update package, and InstallAware, then reboot; finally reinstall InstallAware, and the latest update package.
Users browsing this forum: No registered users and 115 guests
