EXE is not updated during a patch
joakes
Post by joakes »
There is a similar post in tech support by another user that has gone unanswered for over one year. As a pre-sales evaluation, that seriously concerns me.
Anyway, my question is:
I've created an installer (v3.0.0)
Installed on a test machine
Created a backup for reference purposes.
Created a patch, and web update. (v3.0.1)
Copied all files to web server.
Update is found, downloaded, and installs.
However, the EXE (and other changed DLLs) are not updated.
When I run the EXE I'm still using the v3.0.0 release.
Why would this occur?
pjach
Post by pjach »
I have the same problem. I've created a patch from version 2.1.0 to 2.1.1 and set it as a web update. After it has been installed and all changes have been made version of setup files remained 2.1.0.
Does anyone know where is the problem?
joakes
Post by joakes »
The only thing I've found out so far is that if the client installs from a full web install, then update patches work from the web very well.
If the client installs from a CD though, the web updates don't seem to work.
ronm
Post by ronm »
I was experiencing this same issue and just discovered that it was caused by building the patch from the command-line (via an automation script I am using). If I build the patch through the InstallAware Studio then it works fine.
I am not sure why it doesn't work from the command-line?
rcaspers
Post by rcaspers »
Hi there, I have the same problem. did you ever found a solution?
