I am unable to get "Copy Local Files" to work. It simply appears to do nothing. I have tried with many different parameters, such as:
Copy Local Files C:\\todo.txt to C:\\todo2.txt
Copy Local Files C:\\a\\* to C:\\b
Copy Local Files C:\\a\\*.* to C:\\b
The files and directories exist and even the cases match. I have even stepped through with the debugger to validate the lines are being executed.
Am I doing something wrong?
Any suggestions for seeing why this does not work (e.g. logs, etc...)?
Scott
Copy Local Files Problem
sdeschenes
scarlson43017
Thank you. Of course I had my "Copy Local Files" lines starting the very next line after Apply Install.sdeschenes wrote:Make sure you place those lines before Apply Install.
I suggest that InstallAware add this as a note to the online help for the "Copy/Move Local Files" command, as it appears multiple people have been burned by this.
