Difference between \"Run Application\" and \"(Un)Install MSI\"?
plokolp
Post by plokolp »
Hello fellow installers.
I am evaluating IA and have a question.
I need to install Crystal Reports 2008, and according to this webiste
http://support.businessobjects.com/down ... ime.asp#08
Crystal Reports recommends using a .MSI over a merge module (.msm).
So the question I have is, what is the best way of executing a .msi file?
Is it...
1. Use the "Run application" or.
2. Use the (Un)Install MSI Setup in the scripting options.
It seems that both methods can do the same thing, but I'm wondering which on is best....particularly for "best practice Vista setup"?
Thanks and best regards,
Rod.
