Can't build patch
paulk
Can't build patch
Post by paulk »
I'm very new to using InstallAware and have been unable to build a patch for my web or compressed builds. I add a patch by pointing it to the previous build and start the BUild Patch. The patch building starts, but hangs and never finishes. I've left my pc for hours doing this and it never finished. I've tried this several times, and resolved that I must be doing something wrong which doesn't allow it to finish. Any help would be greatly appreciated.
Clicking Build Patch messages:
Building Project: CPKTest
Output Folder: J:\\APP.CPKTest\\Patch\Deployment Type: Patch
Code Signing: Disabled
Compression: Best
Compiler Variables: UPDATE_SERVER=http://apps.CPKTest.com/updates.ini
Cleared output folder J:\\APP.CPKTest\\Patch\Built plug-in action Download File
Copied file D:\\CPKTest\\RELEASE_BUILD_BINARIES\\ComponentFactory.Krypton.Toolkit.dll
....Copies all the files
Built installation executable
Injected setup languages
Storing support files: componentstree.dfm (0%)
Storing support files: finish.dfm (9%)
Storing support files: maintenance.dfm (19%)
Storing support files: registration.dfm (29%)
Storing support files: startinstallation.dfm (38%)
Storing support files: update_install.dfm (44%)
Storing support files: update_setup_finish.dfm (55%)
Storing support files: update_setup_welcome.dfm (65%)
Storing support files: wizard.dfm (75%)
Storing support files: mDownExec.dll (94%)
Injected runtime files
Beginning processing for patch J:\\APP.CPKTest\\Patch\\CPKTest_1_0_1_63.zip.msp
Extracting patch reference data from D:\\CPKTest\\DEPLOYMENT_BUILDS\\CPKTest_BaseBuild\\Release\\Web\\CPKTest_1_0_1_61.zip.exe: CPKTest_1_0_1_61.zip.msi (0%)
Processed base package J:\\APP.CPKTest\\Patch\\Base Package 1\\CPKTest_1_0_1_61.zip.msi
Extracting patch reference data from J:\\APP.CPKTest\\Archive\\Release\\Web\\1.0.1.62\\CPKTest_1_0_1_62.zip.exe: CPKTest_1_0_1_62.zip.msi (0%)
Processed base package J:\\APP.CPKTest\\Patch\\Base Package 2\\CPKTest_1_0_1_62.zip.msi
Creating patch J:\\APP.CPK Test\\Patch\\CPKTest_1_0_1_63.zip.msp
