Numeric Comparison
Numeric Comparison
How can I do numeric comparisons? The Mathematics function doesn't work and the other operators do string compares.
Mathematics works, of course. If automatically does numeric comparisons when both parameters resolve to numeric values.
No. Mathematics does not work for me.
~InstallAware Clipboard Data~
~Comment~
~{BA079DA4-72C8-4D70-B425-DDA21BF4C856}~
~Terminate Install~
~{76C49C8E-9653-43AF-A9A4-CC0C8B7573EB}~
~MessageBox~
~{69B7211B-4D05-41E9-B1FE-38AD1FBCB108}~
~$Var2$~
~0~
~1~
~Mathematics~
~{EC052B3B-00D3-4F9D-9DFF-91CB50DD0048}~
~Var1~
~5000~
~0~
~Var2~
~Set Variable~
~{296E37AA-DDDB-48E1-A984-396B137146FA}~
~Var2$MYAH$MYAH$FALSE~
~0~
~Set Variable~
~{60CE1C91-A955-4B3A-AE2D-63DDA9590F6F}~
~Var1$MYAH$MYAH$FALSE~
~10000~
That simple program gives me an empty string. Now what?
~Comment~
~Terminate Install~
~MessageBox~
~$Var2$~
~0~
~1~
~Mathematics~
~Var1~
~5000~
~0~
~Var2~
~Set Variable~
~0~
~Set Variable~
~10000~
There's a bug in your code
Var2 = Var1 + 5000
is wrong
$Var2$ = $Var1$ + 5000
is correct
Var2 = Var1 + 5000
is wrong
is correct
OK. That works, but this doesn't. Checking disk space was how this all started for me.
~Terminate Install~
~MessageBox~
~$Var2$~
~0~
~1~
~Mathematics~
~$Var1$~
~5000~
~0~
~Var2~
~Set Variable~
~0~
~Check Disk Space~
~{55EA3C8C-4A58-470C-BD9D-FA80B2A4F975}~
~Var1~
~c:\\~
~TRUE~
~FALSE~
~Set Variable~
~{AADCFFC9-ADBF-4A9E-AF31-16CAD8562016}~
~0~
~Terminate Install~
~MessageBox~
~$Var2$~
~0~
~1~
~Mathematics~
~$Var1$~
~5000~
~0~
~Var2~
~Set Variable~
~0~
~Check Disk Space~
~Var1~
~c:\\~
~TRUE~
~FALSE~
~Set Variable~
~0~
The value is an Int64 value which is creating the problem. We should have an update for this very soon!
Fixed yet?
Is this bug fixed yet?
This still fails:
Get Free Space on C:\\ into variable availDiskSpace
Set Variable reqSpace to 2048000000
Evaluate Expression $availDiskSpace$ >= $reqSpace$ into variable diskSpace
diskSpace will be false, where it should return true ($availDiskSpace$ while running this is well over 2 GB).
Is there any other way to check for free disk space?
This still fails:
You should use If for that. Evaluate Expression performs logical operations on strings only.
I am trying to perform the same operation as Klavelle. I have tried using the Evaluate Expression command, the Eval command provided by the Camelot plug-in and I have used the standard If statement. I have varA set to 1978 and varB set to 16327196672. When I check to see if varA is greater than varB, the Evaluate Expression and Eval commands return True and the if statement also returns true.
You mentioned that the value is an Int64 value. Did you ever get a fix for this?
Yes, try with InstallAware 9.01.
Users browsing this forum: No registered users and 29 guests
