If SQL Server is not installed, the setup pre-requisite correctly installs it. But the newly installed instance is not returned by Detect MS SQL Instances. I am able to access it through SQL Server Mgmt Express. Also, an install I created in Wise can see the instance.
If I reboot and then run the install, Detect MS SQL Instances correctly returns the instance.
Anyone have any ideas?
Instance not detected on new SQL Server install
Ron San Martino
Ron San Martino
More
Also, no other SQL Servers on the network show up. I found that after a varying amount of time (5 minutes to 30+ minutes), it starts working. The instance I just installed on my machine appears along with the other SQL Servers.
I found some some Delphi code (ListAvailableSQLServers) on the web that searches for available servers. It behaves the same way.
In this code, if I change:
SourcesRowset := CreateComObject(ProgIDToClassID('SQLOLEDB Enumerator')) as ISourcesRowset;
to:
SourcesRowset := CreateComObject(ProgIDToClassID('SQLNCLI Enumerator')) as ISourcesRowset;
It works correctly.
to:
It works correctly.
