HELP simple 'Check Registry' problem
tht
Post by tht »
Simple task, I just need to verify the existance of a key. This is the key:
Variable
Set Variable EXPLORER to "val"
function Call
Check Registry Key HKCU\\Software\\3M\\GPS Firmware Upload Utility\\Configuration\\BaudRate
and here is the key from the registry
HKEY_CURRENT_USER\\Software\\3M\\GPS Firmware Upload Utility\\Configuration\\BaudRate
and no value in the 'Value' so it should return the '9600' or 'NO$KEY'
where BaudRate = 9600 <- this is a string value
This is my if-code
If variable EXPLORER Equals (ignore case) NO$KEY
else
This Fails everytime not to mention I used 'Read Registry' and have simular results.
HELP and THANKS!
Here is the clipboard data for my code
~Set Variable~
~{9E42BAE4-563D-4C55-8E3C-B44762B45406}~
~EXPLORER$MYAH$MYAH$FALSE~
~"Val"~
~InstallAware Clipboard Data~
~Check Registry~
~{97102503-41EF-4272-A8F7-86BE3F820187}~
~EXPLORER~
~1~
~Software\\3M\\GPS Firmware Upload Utility\\Configuration\\BaudRate~
~If~
~{4C852E6D-072E-4B3F-A2C9-55A89678564B}~
~EXPLORER~
~4~
~NO$KEY~
~FALSE~
~MessageBox~
~{5CED53B7-7AD1-47C2-B104-0A388EA3D3D1}~
~$EXPLORER$ Setup Error~
~No previous versions of ITS Explorer.$NEWLINE$~
~3~
~1~
~Else~
~{446416C2-AA0F-4D88-9D63-2DCCE2821B68}~
~MessageBox~
~{1139BFED-DBCB-4B35-8905-BF65BE795920}~
~A previous version of ITS Explorer needs to be removed before installation can continue.$NEWLINE$$NEWLINE$Setup cannot continue.~
~3~
~1~
~Terminate Install~
~{AC8F74D5-ED02-46B6-8E9A-1C9A9BD82764}~
~End~
~{9D2F7690-C2E8-440D-8BB5-7CC9C40232A4}~
