I am new to IA Express and have two questions:
1. Since I can't remove the "Run App" checkbox, how do I set the application that is called by it. I have several exes that are distributed with the installer.
2. Is there any way in Express to edit choices made during the Project Wizard? ex. I selected the MDAC 2.8 refresh and now want to remove it without recreating the entire installer.
I have 6 programs that I am using the Run programs function to handle at the end the installation. I am registering a bunch of ActiveX EXEs with the /REGSERVER command line options and one other msi file that I need to monitor completion of before continuing execution of the main application. Am I going to be able to pull this off with the Express version.
