Why does a patch require the original install source....?
wirecad
Post by wirecad »
Why does a patch require the original install source on the target machine?
sinan
Post by sinan »
Because patches are incremental - they contain only the latest changes to your files, and not the whole files. In the Project Options window, there is an Include whole files only option which will probably sidestep this issue, but then why make patches - you end up with a full sized setup anyways.
Also read the Patching topic in the online help for how patch source resolution occurs - if you are patching web builds, for instance, this is automatic.
wirecad
Post by wirecad »
Thanks. I'll read further. And thanks for the timely response.
CBH
