Problem with Batch Build
Gareth Owen
Post by Gareth Owen »
I have a strange isue with the batch build option in IA2005
When I try to batch build all of the main installation types, I get the error
Error during build: No files matching pattern "#RXDSOURCE#<Some file name or other>"
Yet when I run the builds on their own, each one works fine.
I am using compiler variables to specify the source directory of the files.
sinan
Post by sinan »
This is a known issue - batch builds within the IDE do not apply compiler variables. This issue will be addressed very soon in an update.
In the meantime, I recommend using the command line build tool, or stand alone builds in the IDE. Apologies for the inconvenience :cry:
Gareth Owen
No probs, just so I wasn't going completely mad :wink:
