I am evaluating IA and was under the impression when I downloaded the eval that IA supported multiple languages. I have used the Localization tool to export the translation files. But I need to produce an install in a half dozen languages and do not have time nor the resources to translate everything manually. I read posts about a language pack.
Does IA have an existing language pack that contains the translations for the common dialogs that I can use? If so, how can I get it?
Language Pack
InstallAware setups can be localized into 34 languages. However, we do not provide or sell pre-translated language kits. You will need to do the translation work yourself, or work via a third party. The good news is that all editions of InstallAware support localization, and they can export/import strings from your project - so you just send your strings to your translator, and never the entire setup project and/or its sources or the InstallAware IDE.
Payal Gupta
Obliterator
I'm also currently evaluating IA8 and was under the same impression. I just wondered is this still the case?
I'm looking to migrate from IS and so far IA seems to offer a number of advantages - particularly at making common tasks quick and simple. In fact its a refreshing change to not have to jump through huge hoops! Not providing translations for standard dialogs out of the box seems illogical especially when compared with your competition (IS provides multilingual packs for free download out of the box).
Having each IA user translate the whole dialogs (and presumably MSI error messages, etc) again and again just doesn't seem to make sense? Its a massive repetition of unnecessary work for your customers.
Do I misunderstand? Or is there a community repository which has built up ready to go localisation imports for each language?
Obliterator
