Has anybody tried (and succeeded!!) to create a plug-in that shows a dialog at Run time, not just IDE time? If so, how did you do it? I'm trying to do it because I need to do some fairly complex processing at run-time and I have to ask the user questions and have them make selections.
I know there is only pure win32, so I'm trying using ATL (so far, so good!). But, that's where the fun begins! My test case is the following:
1) Display the Welcome Dialog, user clicks Next
2) This welcome dialog is closed and my Dialog is called
3) It has next/cancel and a single field that displays a Variable value.
Well, the Welcome screen does not get closed (I tried Hide Dialog and that did not work), the variable value does not go into the edit field and than non of the buttons actually events seam to get fired!!!!
Anybody got any suggestions? I'd be most appreciative:)
Andy.
Plugin with a Dialog at Run Time?
hide welcome dialog
Hi did you get solution how to hide dialog.
I'm doing the same thing.
1. First calling Welcome dialog.
2. the next in welcome dialog calls another setup with its own dialogs to display
3. Before calling this new set of dialogs I want to hide or remove the welcome dialog
how can i do this ?
Thanks in advance.
how can i do this ?
Thanks in advance.
Hope this workes for you both
Hi there, i had a simular problem and used the next trick to solve it
see the code below
see the code below
this is better reading
function RunTimeExecute(Window: THandle; Variables, State: PChar; Progress: TPlugProgressIndicator;
var Return: Integer; NewVariables: PChar): Integer; stdcall; export;
begin
Return := 0;
if NewVariables = nil then
begin
Plugin.State := State;
Plugin.Variables := Variables;
MyDialog(Window);
Result := Length(Plugin.Variables);
else
begin
Result := 0;
StrCopy(NewVariables, PChar(Plugin.Variables));
end;
end;
procedure MyDialog(_Parent: THandle);
var
Form1: TForm1;
SetupCaption: String;
ModalResult: integer;
begin
// do NOT use Hide Dialog in you IA project
// Create a form whitout a border
// u can use the same design as the original setupwindow
// including three buttons Back, Next and Cancel
// make the align property alClient
// make the handle of the original setupwindow the parent of your dialog
Form1 := TForm1.Create(nil);
// The parameter _Parent is given to you when calling the plugin
// However its is alway 0 (see my own topic a while ago)
// i believe it is a small bug in IA and hope it will be solved
// i used the findwindow function. this only works while IA does not change their classnames
SetupCaption := Plugin.GetVariable('$TITLE$') + ' - InstallAware Wizard';
Form1.ParentWindow := FindWindow('TPoolTemplate',PChar(SetupCaption));
ModalResult := Form1.ShowModal;
case ModalResult of
Cancel: Plugin.SetVariable('WIZARD', 'CANCEL');
Ok: Plugin.SetVariable('WIZARD', 'NEXT');
Next : Plugin.SetVariable('WIZARD', 'BACK');
end;
Form1.Free;
//plugin is a object of a small class i wrote
//getvariable and setvariabele are two functions whitin that class
//they get and set the values from the property Plugin.Variables
end;
TPlugin = class(TObject)
private
FVariableList: TStringList;
FStateList: TStringList;
FStateCount: Integer;
function GetState: String;
function GetVariables: String;
procedure SetState(Value: String);
procedure SetVariables(const Value: String);
protected
function GetDesigntimeText: String; virtual;
public
constructor Create; virtual;
destructor Destroy; override;
function GetVariable(VarName: String): String;
function SubstituteVariable(Variable: String): String;
property DesigntimeText: String read GetDesigntimeText;
procedure SetVariable(Varname, Value: String);
property State: String read GetState write SetState;
property Variables: String read GetVariables write SetVariables;
end;
thanks a lot..!
This is the first time i'm seeing this code that is custom to what installaware offers.
Where should I add this code too..! I mean how can I create custom funtions or code like the one you have shown me. I'm using installaware admin studio.
I will try to use what you have shown in above the code...let you know pretty sonn.
Thanks again.
Thanks again.
Until now (we're using IA6.6) I used the trick to show a non-modal dialog of 1x1 pixel, and hide dialog right after it, this was working perfectly to get rid of the IA dialog before showing my own plugin-dialog.
Now, I'm testing with (a demo version of) IA 9.06, and this trick is resulting in a window saying "Unspecified Error"
I tried to enlarge the non-modal dialog to 100x100 but the same problem. Anybody an idea? I need to get this fixed before I can buy IA9 and migrate my application to IA9.
Thanx
Thanx
Users browsing this forum: No registered users and 99 guests
