InstallAware v8 VS2008 Problems and Questions
Shmulik28
Post by Shmulik28 »
I just installed the latest version of IA v8 and was trying out using installaware as part of Visual Studio 2008 (on Vista) - when I try and run Installaware after building my project, I get this error:
Building Project: SesLiteSetupUtility
Output Folder: C:\\projects\\SSI-Project Repository Projects\\SesLiteSetupUtility\\trunk\\InstallAware\\Release\\Uncompressed\Deployment Type: Uncompressed Directory Layout
Code Signing: Enabled
Compression: Best
Compiler Variables: "UAC=requireAdministrator",FALSE
Cleared output folder C:\\projects\\SSI-Project Repository Projects\\SesLiteSetupUtility\\trunk\\InstallAware\\Release\\Uncompressed\Built plug-in action Windows Installer
Built plug-in action .NET Framework
Built plug-in action (Un)Install MSI Setup
Copied file C:\\projects\\SSI-Project Repository Projects\\SesLiteSetupUtility\\trunk\\SesLiteSetupUtility\\bin\\Release\\SesLiteSetupUtility.exe
Copied assembly C:\\projects\\SSI-Project Repository Projects\\SesLiteSetupUtility\\trunk\\SesLiteSetupUtility\\external\\DotNetBar\\DevComponents.DotNetBar2.dll
Copied assembly C:\\projects\\SSI-Project Repository Projects\\SesLiteSetupUtility\\trunk\\SesLiteSetupUtility\\external\\Licensing\\bin\\Debug\\SoftwareSecure.Licensing.Client.dll
Copied assembly C:\\projects\\SSI-Project Repository Projects\\SesLiteSetupUtility\\trunk\\SesLiteSetupUtility\\external\\Xceed\\Xceed.Ftp.dll
Copied file C:\\projects\\SSI-Project Repository Projects\\SesLiteSetupUtility\\trunk\\DemoSesLiteCleanup\\bin\\Release\\DemoSesLiteCleanup.exe
Copied assembly C:\\Program Files\\Xceed Components\\Bin\\.NET\\Xceed.Ftp.dll
Error during build: Unable to merge Windows Installer database with module
What am I missing??
Also, the Menu item "InstallAware > Launch InstallAware" does nothing. How do I configure it to launch IA?
I've modified VS2008 to require launching as administrator (I think IA requires that it is launched as administrator?), but that has no effect from inside VS2008 (outside of VS it runs fine).
