I build custom setups for each client and each of them have a custom DLL made exclusively with their license details.
Is patching still a possibility in this scenario? Or would I need to build custom patches for every client?
Thanks!
Ignoring certain files to make a patch?
Roostar2004
You can set the following checks
[compiler if Variable BUILDMODE Equals PATCH]
[compiler end]
This will tell the complier to only go into this section when you are builind a patch. You can also do
[compiler if Variable BUILDMODE not Equals PATCH]
[compiler end]
This will tell installaware to go into this section when the complier is not building patches.
I am not sure if this is the information you are wanting or not.
[compiler end]
[compiler end]
