Hi there,
the new version 1.2.4 of mdPLUGINS for InstallAware fixes a bug which can cause changed variable values if you are using the new InstallAware version 8. All plug-ins of the mdPLUGINS package are affected. The plug-in routines which handles variables are rewritten and work now with all versions of InstallAware - incuding the latest main release 8. If you are using mdPLUGINS we strongly recommend to update to the new and fixed version 1.2.4 which can be downloaded here:
mdPLUGINS for InstallAware 1.2.4
Thank you,
Markus
