BDE requirements
Orionizer
BDE requirements
Postby Orionizer » Tue Nov 29, 2005 9:32 am
Is there a plugin available or a scripting method available to do the following:
1. Determine if the Borland BDE is installed and determine the version
2. If it is not detected, install BDE
Thanks!
sinan
Postby sinan » Tue Nov 29, 2005 6:29 pm
Sorry, none at this time. You can merge the BDE merge modules with your project though - that should take care of installing BDE when its missing.
Orionizer
Postby Orionizer » Tue Nov 29, 2005 6:32 pm
sinan wrote:Sorry, none at this time. You can merge the BDE merge modules with your project though - that should take care of installing BDE when its missing.
Thanks for the reply! Do you have an example of how to do this? Also, is this something that is planned for a future release?
sinan
Postby sinan » Tue Nov 29, 2005 6:35 pm
Sorry, no samples...I apologize. Just find the BDE merge modules in your Borland product folders, add them to your project.
Because BDE is by now a retired legacy technology, we will not be developing new plug-ins to support it - although other users of InstallAware might be able to do so using our open plug-in architecture.
Orionizer
Postby Orionizer » Tue Nov 29, 2005 6:38 pm
Thanks Sinan...
Yes, I know it's OLD and RETIRED and I plan on moving every project I have to DBISAM eventually. I just haven't had the time, but guess I'll have to make it... :wink:
Frede
Re: BDE requirements
Postby Frede » Mon Dec 19, 2005 8:03 am
Orionizer wrote:Is there a plugin available or a scripting method available to do the following:
1a. Determine if BDE is installed:
function BDEInstalled: boolean;
//Check if BDE is installed by trying to init the BDE
begin
result := (dbiInit(nil) = 0);
if result then
dbiExit;
end;
1b. Determine the version:
See http://www.delphifaq.com/faq/delphi/database/f72.shtml
2. Install BDE
You can find the latest BDE merge modules here:
http://info.borland.com/devsupport/bde/bdeupdate.html
The examples are in Delphi. I have it in an MSI dll. Let me know if you need the source and I get send it to you.
/Fredrik
Orionizer
Postby Orionizer » Mon Dec 19, 2005 8:09 am
Thanks Frede!
Users browsing this forum: No registered users and 13 guests
