HelloWorld
Posts: 25 Joined: Wed Nov 23, 2005 10:21 am
Post
by HelloWorld » Wed Nov 30, 2005 8:43 am
i need to make a check/install plug-in for a product. Is there an example for this particulare need?
HelloWorld
Post
by HelloWorld » Thu Dec 01, 2005 2:28 pm
OK, made a plugin by myself.
Now a Delphi-question. I need to install a application, like
msiexec -p "somepackage.msi" /silent /noreboot
How can I check if everything went ok?
If someone has an example in any other language, please help....
sinan
Posts: 1036 Joined: Sat Nov 13, 2004 8:12 am
Post
by sinan » Thu Dec 01, 2005 3:37 pm
Hmm, might be best if you use the built-in
(Un)Install MSI Setup plug-in for that. It already features:
* full command line support
* full install/uninstall support
* full progress capture
* pretty much everything else
No need to reinvent the wheel
HelloWorld
Post
by HelloWorld » Thu Dec 01, 2005 3:41 pm
If i use the Install MSI Setup the msi-package can't be in a media block. Or how can I achieve that?
sinan
Post
by sinan » Thu Dec 01, 2005 3:46 pm
Good point. You may use the Bundle Files plug-in available on this forum to put the MSI in a weblock. Or you may use the Download File plug-in to download it dynamically.
HelloWorld
Post
by HelloWorld » Thu Dec 01, 2005 3:54 pm
The problem of Download File that it makes the Single Setup pretty useless and i cant see how Bundle Files will solve my problem...
sinan
Post
by sinan » Thu Dec 01, 2005 3:55 pm
Bundle Files does exactly what you want - it adds files to a project as sort of "support files", but can put them in web media blocks. So you can serve both single and web builds automatically with it.
HelloWorld
Post
by HelloWorld » Thu Dec 01, 2005 4:16 pm
Just a question, Bundle Files has a result value. What can be the possible result values?
sinan
Post
by sinan » Thu Dec 01, 2005 4:34 pm
I do not know - I believe the plug-in author should be able to help.
wolbrink
Posts: 76 Joined: Wed Nov 17, 2004 3:00 pm
Post
by wolbrink » Fri Dec 02, 2005 10:16 am
HelloWorld wrote: Just a question, Bundle Files has a result value. What can be the possible result values?
"SUCCESS" or "ERROR"
--Troy
