I Use the Plug-In "Detect MS SQL Instances". Under the version 7 was this code correct. With the version 8 i had this problem. When I comment the "Detect MS SQL.." i chan start the Setup correctly
Emample:
Set Variable AVAILABLESERVERS to
Set Variable MSGTESTVAR to TEST
MessageBox: , $MSGTESTVAR$
DETECT MS SQL Instances : get result into variable AVAILABLESERVERS
When i Run the Setup, the First MessageBox show me the correct text "Test"
After the Detect MS SQL Insances... the Setup messagebox shows me only the $MSGTESTVAR$ . But the Variable has loose the value.
This Problem is also under new "Project--> MS SQL Server Connection"
ErrorMSG: Runtime error in setup script: Line 38 '' is not a valid integer value
Thanks for Help
