Probem writing to registry
Gareth Owen
Postby Gareth Owen » Thu Dec 01, 2005 2:39 am
As part of our install, we might need to install 3rd party drivers. In this case the only way of telling if these drivers are installed is by checking for a key in the reg.
I know this is not possible at the moment :( , but as a work around, I was going to write a value into this key when we install the drivers so it will only do it once.
Issue: I want this reg entry to be written if the drivers are installed (currently done after the end of the Apply Install) and I do NOT want it removed on uninstall.
If I add the reg entry into the main install, it gets removed on uninstall.
If I add the Write Reg Key at the same place I install the drivers, it does not seem to write anything to the Reg.
How would be the best way to do this?
sinan
Postby sinan » Thu Dec 01, 2005 6:46 am
It is possible to create a key (no values) and persist it. Would this work? If so, set the Value field to + and leave the Data field empty and choose the String type.
Gareth Owen
Postby Gareth Owen » Thu Dec 01, 2005 7:45 am
Unfortunately not, This was for the workaround because we could not tell if the key was present. :cry:
sinan
Postby sinan » Thu Dec 01, 2005 8:13 am
Not to worry, a new Check Registry command lets you test for the presence of keys, and returns specific conditions based on the type of data found :) Again, I have to ask you to contact me privately for the details :)
Gareth Owen
Postby Gareth Owen » Fri Dec 02, 2005 3:53 am
:D Wonderful, will send you an email.
Users browsing this forum: No registered users and 38 guests
