InstallAware v5.0 Public Beta
Post complete new themes or wizard dialogs here.
sinan
Post by sinan »
The Public Beta of InstallAware v5.0 is here!
What's New:
  • • Write Registry Command with expanded parameters
    • Check Registry Command to test if a registry key exists
    • Collapse and Expand Options for all code folding regions
    • Emitting Application Version Information to setup.exe files
    • Application Runtimes visual view in IDE to visually manage your pre-requisites
    • SQL Server 2005 plug-in to automatically install Microsoft SQL Server Express
    • Updated Templates, Wizards, and Samples compatible with the new visual runtimes
    • Transform Instance command to spawn new instances of a product
    • New Pre-Defined Variables that can be used with transformed instances and versioning
    • New Commands that detect running services and processes
    • Updated IDE and Command Line Tools that work with include scripts
    • Fixed .NET version detection issues in the new plug-in packages
    • Copy as Text option to make it easier to copy human readable script code
    • Welcome Page in IDE with helpful links and recent projects
    • Multiple Scripts in IDE to edit and work with more than one script
    • Code Navigation in IDE to rapidly view and browse sections of your setup scripts
    • Include Scripts command to use includes for frequently used script actions
    • Database Import Wizard to convert MSI/MSM files into InstallAware scripts
    • Updated Plug-Ins to support the latest Microsoft technologies
    • Speed Enhancements in the IDE, compiler, and runtime files
The most exciting feature in this version is the ability to use include scripts. This adds a great level of power to InstallAware, in a way that was not possible before.
The include scripts technology has been leveraged to create a new visual view that manages the installation of application runtimes. You may now check and uncheck any selection of application runtimes and your setup scripts will be automatically updated to work with them. Checking a runtime that has further dependencies will automatically check those dependencies as well.
Another very exciting feature is the ability to install multiple instances of a product, with a single scripting command. No instance transforms are required, and Windows Installer 3.0 is not required either.
Finally, the Windows Installer converter lets you reverse engineer any MSI or MSM database and convert it to an InstallAware setup. This lets you customize existing packages or take peeks at what they do.
A Studio evaluation download is now available for this product:
http://www.installaware.com/blockspon/i ... io_sfx.exe - 201 MB download, single file "offline" setup http://www.installaware.com/blockspon/i ... studio.exe - 27.1 MB download, web based "online" setup, total download may reach 205 MB
Enjoy!
