Hi
When i install the Patch and then uninstall it, it uninstalls correctly but the shortcut remains
why is it so??? What i need to do to sollve this problem
After uninstalling the Patch shortcut remains
sherry gomindes
FlorianSchmelzer
Re: After uninstalling the Patch shortcut remains
IA10.10
same issue ?
is there a fix ?
same issue ?
is there a fix ?
Uninstall as in remove the patch or the entire program?
FlorianSchmelzer
uninstalling the whole patched software.
Can you please send us a small reproducing project to support at installaware.com?
