Modify/Repair Problems
HelloWorld
Postby HelloWorld » Fri Dec 02, 2005 10:27 am
i am using the public beta right now and have a little problem with this version or all versions.
~InstallAWARE Clipboard Data~
~End~
~{20581C27-C9E5-4C57-9AE7-15423C5B56B1}~
~Compiler Variable End~
~{E4F6EA82-B5C9-421B-A9A0-4CE95C1AD63F}~
~Comment~
~{1C1C7316-D01E-42A4-95D8-CCB87DB0E9E7}~
~First Time Install~
~Set Variable~
~{9F667340-3F2E-4062-8163-1195428D1DF6}~
~STARTMENU~
~Set Variable~
~{00B4BD5D-9731-4166-B93D-D060509E2C05}~
~TARGETDIR~
~$PROGRAMFILES$\\My Company\\My Program~
~Compiler Variable If~
~{D7CD77F3-F37C-4B3C-8AA1-BFFC00553360}~
~BUILDMODE~
~0~
~PATCH~
~TRUE~
~Else~
~{3EE3280B-D5CD-4DAE-99DE-5EEA3F2BE968}~
~GoTo Label~
~{48E80339-1D64-48BD-8A59-455360DAA800}~
~Maintenance~
~If~
~{2704941E-EEC6-41E6-BE08-4CE11AA21AD8}~
~MAINTENANCE~
~0~
~TRUE~
~FALSE~
This works fine, everything is installed in the correct directory. But when I do a repair/modify, there are several errors:
There is a new directory: Program Files\\My Program
The shortcut in the startmenu is pointing to Program Files\\My Program\\program.exe
When I deselect some items upon install, but when I do a modify all features are selected. What do I do wrong?
sinan
Postby sinan » Fri Dec 02, 2005 10:57 am
First, if you did any work (or builds) with the non-public beta, uninstall all of them. The non-public beta had an issue which might be causing this problem.
Next, rebuild the base product (and any patches) in the public beta version, and try again.
Finally, if you still have problems, please provide an exact step-by-step sequence of reproducing them, including UI choices made in the installer such as TARGETDIR, Start Menu, etc...
HelloWorld
Postby HelloWorld » Mon Dec 05, 2005 12:38 pm
Hi sinan,
i sent you an email with attachment (9 mb), please let me know if you received it.
sinan
Postby sinan » Mon Dec 05, 2005 7:58 pm
I took a look at your project. It might be happening because you are using an unqualified TARGETDIR path, and an empty STARTMENU value when initializing the variables. Try to use a fully qualified TARGETDIR and a properly initialized STARTMENU variable and see what happens that way (template projects already do this for you).
Users browsing this forum: No registered users and 37 guests
