Is there a way to have the installer remember the previous feature selection in upgrade/update mode? At the moment it does an uninstall, and then starts afresh. Can the script be changed to do this?
Matthew
Remembering selected Features in upgrade
I think I'm going to need more help on this one. Looking at the script, I've defined 4 components. The install part uses the Get Component State function to put the selection into SELECTED. But the dialog that shows the selector has an object action to put the result into COMPONENTS, which isn't listed in the pre-defined variables.
It therefore seems that I cannot just store the contents of the components string and save that in the registry, but I must instead do some additional code to save each component seperately, and then later use the SetComponentState to restore them. Is this the case?
I presume that I can restore the state at any point in the script to have it work okay? Or are they initialised only at the "define components" section?
Thanks, Matthew
Thanks, Matthew
Yes - that is precisely the case. You need to read the selection state for the individual components using Get Component State, and later set them individually using the Set Component State.
If you are planning on using the registry for storing component states, do the following:
1) Move the code that defines your components all the way to the top of the script
2) Before "Apply Install", add the registry commands to save your feature selection information
3) Before "Install/Remove MSI Package", add the registry commands to read your feature selection information (if you add them after here, they will already have been removed)
Hope this is useful
Hope this is useful
Okay, for anyone else who is interested, the following works fine. I preserved the state of the "install type" variables too, since it makes sense. You can just copy/paste these lines into the script and it will look a lot nicer! You may want to modify the YourCompany and YourProduct with a search and replace first.
Right at the top (moved from lower in standard script)
Before Install/Remove MSI package
Before Apply Install:
Matthew Jones
~InstallAWARE Clipboard Data~
~Define Component~
~{E4695060-EB59-426C-80F6-D1A0A22F5409}~
~Full manuals (PDF)~
~TRUE~
~Reference Manual, User's Guide and Introduction in PDF format~
~Define Component~
~{15DD84A8-0BAD-4B07-98B2-2B582ACC7853}~
~Sample models~
~TRUE~
~Sample models~
~Define Component~
~{A2D52C62-1C8C-431C-B9E1-73026317AB08}~
~Help and tutorials~
~TRUE~
~Define Component~
~{20122FD3-B078-4AF2-AC31-ABFB74DF79E7}~
~Main application~
~TRUE~
~Main application files - required~
~Comment~
~{8BE18D7D-1203-4E92-8025-E050E49431A5}~
~Define Setup Components~
~Read Registry~
~{FAD357F9-A57A-42EE-834B-1E08332238FD}~
~PERSONALIZED~
~1~
~Software\\YourCompany\\Installer\\YourProduct~
~Personalized~
~Read Registry~
~{F5754A36-A0B3-4472-B068-E8726DC7452C}~
~MINIMUM~
~1~
~Minimum~
~Read Registry~
~{52C461A5-55C6-48A3-B591-E00736E5F578}~
~COMPLETE~
~1~
~Complete~
~End~
~{F753F422-CC44-4F4D-A630-C2F96E8FCF61}~
~Set Component State~
~{DCC68235-B80D-42F9-9020-C557C53BE74D}~
~FALSE~
~If~
~{48BE5E13-8F80-4142-9E4D-314A94FE844B}~
~BX_COMPONENTSTATE~
~0~
~FALSE~
~FALSE~
~Read Registry~
~{6C532DA6-FD67-422C-859D-845FC3391C11}~
~BX_COMPONENTSTATE~
~1~
~PDFs~
~End~
~{30000859-F00B-4489-956D-EEA30E9405D0}~
~{D786D78F-8FA3-492F-862D-1FDE6B9DAA4D}~
~Sample models~
~FALSE~
~If~
~{71361234-EB86-4957-A2C7-3EED4B873CBB}~
~BX_COMPONENTSTATE~
~0~
~FALSE~
~FALSE~
~Read Registry~
~{A2A77A51-57B7-43B8-8D46-4CA48E03A8D7}~
~BX_COMPONENTSTATE~
~1~
~Samples~
~End~
~{D0B3F99C-1A71-49DB-B52C-FCF23FC8D325}~
~{3CC2B6E6-BE09-4854-BB45-2C63F902E45A}~
~FALSE~
~If~
~{BEA8AB58-200F-4E1D-8398-5DB88F0D93CE}~
~BX_COMPONENTSTATE~
~0~
~FALSE~
~FALSE~
~Read Registry~
~{F4E5CAAF-61F5-4372-BCD2-813F42B1B0E8}~
~BX_COMPONENTSTATE~
~1~
~Help~
~End~
~{E0DE1E96-EAB8-4E14-BA73-377E5577F022}~
~{48220F35-979E-410B-8085-2246A6A0C5D8}~
~Main application~
~FALSE~
~If~
~{2C2CBFC0-2082-4B1A-A42A-1998CC06F87C}~
~BX_COMPONENTSTATE~
~0~
~FALSE~
~FALSE~
~Read Registry~
~{552D5D2C-E246-4030-8EC4-9E0F48E5C9A4}~
~BX_COMPONENTSTATE~
~1~
~MainApp~
~Write Registry~
~{838B8C9C-9149-463D-AF1B-0966D0268FEF}~
~0~
~1~
~Personalized~
~$PERSONALIZED$~
~TRUE~
~FALSE~
~Write Registry~
~{14DCF537-E4A2-40D6-9ECC-05BDE2755296}~
~0~
~1~
~Minimum~
~$MINIMUM$~
~TRUE~
~FALSE~
~Write Registry~
~{FBD21428-BADC-4DCE-B18D-C2E7B885444A}~
~0~
~1~
~Complete~
~$COMPLETE$~
~TRUE~
~FALSE~
~Comment~
~{2FB3B4B1-18FC-42FF-99E8-1345421F619A}~
~Write Registry~
~{58433BE3-7C61-4EF0-8DF0-D5173F867F0D}~
~0~
~1~
~PDFs~
~$BX_COMPONENTSTATE$~
~TRUE~
~FALSE~
~Get Component State~
~{67C44A30-503E-4DB7-A511-BDE3FB662502}~
~BX_COMPONENTSTATE~
~Write Registry~
~{CFF54BB5-7314-4C65-B2E1-E601E9E4758F}~
~0~
~1~
~Samples~
~TRUE~
~FALSE~
~{CC031807-4995-4E1D-87B4-DE1F3C498462}~
~Sample models~
~BX_COMPONENTSTATE~
~Write Registry~
~{FE95E2DC-96B0-43CF-9718-121AD5ECA460}~
~0~
~1~
~Help~
~TRUE~
~FALSE~
~{1C0C4C8A-D862-4990-A599-A98806D6C5F6}~
~BX_COMPONENTSTATE~
~Write Registry~
~{FBE892BA-596F-4614-A231-9F4D9DE3C3D2}~
~0~
~1~
~MainApp~
~TRUE~
~FALSE~
~{5753BD40-C4F3-4B79-A18D-A3B5352FC4FD}~
~Main application~
~BX_COMPONENTSTATE~
Matthew Jones
To be honest, I don't think it is needed. By the time someone gets to this issue, they'll have a project and it will be easier to copy/paste these and adjust them than to do so from another project. Your instructions were easy, but I thought it would be worth passing on a tested set of lines that did the work.
Matthew
Matthew
