Setup keeps detecting that .NET 1.1 SP1 is required.
Ade-Derby
Postby Ade-Derby » Tue Dec 06, 2005 10:21 am
Hi
I am having a problem with a setup I have created. On some Windows 98 and XP pcs it says that .NET framework SP1 is required even though it is installed. If you follow through it looks like it is installing and then needs a reboot. On reboot the installer says yet again .NET framework SP1 is required! and you keep going round the same loop over and over again.
I have done a test on one XP pc and uninstalled .NET framework, after the setup has 'installed' .NET framework and rebooted, again it still wants to install it again, however it has not installed the .NET framework
Building a test version seems to show an error occurs, however as there is no actual feed back with in InstallAware I dont know what the error is.
Help please! (running version sp1.passion_update2_rtm.050927)
Adrian
Gizm0
Postby Gizm0 » Thu Dec 08, 2005 6:38 am
Did you do the update on the plugin package?
Please search the forum, there is an update for the plugin package, which does a fix on this problem.
Ade-Derby
Postby Ade-Derby » Tue Dec 13, 2005 4:17 am
Yes, done it got the tee shirt etc
This problem ONLY happens on a FEW pc's at the moment
Any other USEFULL help?
Adrian
sinan
Postby sinan » Tue Dec 13, 2005 7:48 am
Try the latest version - v5.0. Its hot off the press!
Ade-Derby
Postby Ade-Derby » Tue Dec 13, 2005 12:07 pm
Oh dear!
I cannot open my project any more
I get the following error: -
Script Load Error
This script uses a plug-in that is not available on your system:
MSXML 4.0 SP2
Please install this plug-in before opening this script. Closing project now
Any ideas on where I get required plug-in as I dont remember having it before
Adrian
IanM
Postby IanM » Tue Dec 13, 2005 1:02 pm
Ade-Derby wrote:Oh dear!
Script Load Error
MSXML 4.0 SP2
Adrian
Hi Adrian,
Sinan already got this fixed for me. Go into the .mia file which contains your script with Notepad and change any lines with MSXML 4.0 SP2 to MSXML, then save the file. The new version of the plug-in has been renamed.
That should sort it.
Ian
sinan
Postby sinan » Tue Dec 13, 2005 1:48 pm
Thanks for the help, Ian. This issue is also described in the help file - in the upgrading from section.
Ade-Derby
Postby Ade-Derby » Mon Dec 19, 2005 6:32 am
Hi
Thanks for that - all load and re-compiled. Seems to have fixed the issue!
Sorry for the long delay - I seem to have a hell of a problem to log in to this site to post.
Adrian.
