How to force computer to reboot
get101
Post by get101 »
I have a script that writes a registry key. At the end of the install, I want to force a reboot.
I tried this but it didn't reboot:
Set Variable REBOOTCOMPUTER to TRUE
How do I force a reboot?
Post by CandiceJones »
Studying the code at the end of the install:
Comment: End of Installation
Hide Dialog
Display Dialog: finish, wait for dialog to return (modal)
if Variable SILENT Equals FALSE
if Variable REBOOTCOMPUTER Equals TRUE
if Variable SUCCESS Equals REBOOT
Reboot Computer
if Variable RUNAPP Equals TRUE
if Variable REMOVE Equals FALSE
if Variable SUCCESS Equals COMPLETE
Run Program $TARGETDIR$\\mta.exe
Comment: TO-DO: Insert command that starts your application here
<<Code>>
We find the solution to be setting SUCCESS to TRUE as well.
get101
Post by get101 »
Did you mean: We find the solution to be setting SUCCESS to REBOOT as well.
If yes, does this look OK:
    else
    Comment: Force a reboot after installing key!
    Set Variable SUCCESS to REBOOT
Yes of course silly me, sorry!
The code does look OK but for good measure I would ONLY mandate the reboot if SUCCESS is NOT ERROR or CANCEL.
