I have been using the Dialog Editor to make adjustments to some of the dialogs that appear in my installer. Although I know most of the Object Properties and what they do, there are some that I have never heard of or know what they do.
For instance, what is ScreenSnap and PopupMode? There is nothing in the InstallAware help file that explains these properties.
There are a couple object properties that do not affect the dialogs when used in an installer. For example, the Position property affects the dialog only when I am editing it in the Dialog Editor.
In addition, in the Dialog Editor, the Help menu only has an About option. It doesn't have any help files at all.
It would be nice if the InstallAware help files could provide more information on the Dialog Editor and the Object Properties or create a separate help file that is accessible while using the Dialog Editor. Please consider making help files for the Dialog Editor.
Scott Deschenes
