Check Registry on x64
AH-NP
Post by AH-NP »
I have a problem to check registry on Vista64 OS.
I checked this key, HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Microsoft SQL Server\\Instance Names\\SQL with the script method “ Check Registry”. On x32 OS it returns the value correct.
On x64, I checked, HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Microsoft SQL Server\\Instance Names\\SQL, but it returns the value “NO$KEY”.
I tried with script method “Read Registry”, but it’s the same thing.
Are you a solution ?
