Specifying setup types
Ian T
Post by Ian T »
I'm using IA7 R2
How do I specify which files will be installed when the end-user selects Complete, Compact or Custom from the setuptype dialog ?
ulrichard
Post by ulrichard »
Hi Ian,
assuming your setup is based on the "Basic Setup" template.
Comment: TO-DO: Customize your minimum setup here
if Variable MINIMUM Equals TRUE
Deselect Component: Salesman
else
if Variable COMPLETE Equals TRUE
Select Component: Salesman
Comment: Install/Re-Install product
Get Component Salesman Selection State into Variable IsSalesMan
if Variable IsSalesMan Equals TRUE
Install Files #PL_BinPath#\\SalesMan\\bin\\*.* to $TARGETDIR$\\bin, ignore files matching wildcard pattern(s) *\\.svn\\*, include subfolders
Rgds
Richard
http://www.pointline.com
http://www.paraeasy.ch
http://ulrichard.ch
