Version Variable
jimo
Version Variable
Postby jimo » Fri Dec 09, 2005 2:43 pm
The predefined VERSION variable is exactly the same as that under the "Project Properties" at the beginning of the script at the end just before the apply install it has appended the 4th place to the VERSIon.
i.e.: At start 7.50.3212, after apply install 7.50.3212.0
so the 7.50.3212.0 value is being written to the registry instead of the 7.50.3212 value.
THis is in the Final Beta
sinan
Postby sinan » Fri Dec 09, 2005 2:57 pm
The difference may be when running the setup inside and outside the IDE...
jimo
Postby jimo » Fri Dec 09, 2005 5:20 pm
What should it return outside the IDE?
sinan
Postby sinan » Fri Dec 09, 2005 5:28 pm
Outside will be with the .0, inside it will be the exact version number specified in the IDE. Is this not the behavior you are observing?
jimo
Postby jimo » Fri Dec 09, 2005 7:03 pm
Yes, that is it exactly, just wasn't prepared for the difference, can't debug in the IDE parseing the variable on the last occurance of . in the version.
I worked around it.
Thanks!
Users browsing this forum: Baidu [Spider] and 38 guests
